Bratmobile Posted November 21, 2015 Share Posted November 21, 2015 Recently put new front tires on my 86 Brat and noticed a distinct change in handling ~very sloppy. It seemed fine prior to that. Initially thought of front end alignment issues. Took it to a shop & here's the real problem: severely worn rack and pinion bushings. Shop tech has been searching for the parts to no avail.& so have I for most of the morning. Debating contacting suppliers in Australia for "Brumby" parts as a guy I met from Brisbane at a car show said that Brumby's are everywhere down there. Any recommendations/advice would be appreciated~ Thanks in advance! . Quote Link to comment Share on other sites More sharing options...
ihscout54 Posted November 21, 2015 Share Posted November 21, 2015 (edited) Ide reconfirm the diagnosis with my own eyes, if it truly only appeared after new tire mounting. Looks as tho the parts are still semi available. Power steering could require different parts. http://www.abcauto.com/item.wws?sku=45G24013&itempk=118643&mfr=ACDELCO%20PROFESSIONAL&weight=0.130 http://www.amazon.com/ACDelco-45G24014-Professional-Pinion-Bushing/dp/compatibility-chart/B000C9OMV2 Edited November 21, 2015 by ihscout54 Quote Link to comment Share on other sites More sharing options...
Bratmobile Posted November 21, 2015 Author Share Posted November 21, 2015 Thanks for the links~ forwarding them on to the shop now. I'll see what they say. Also came across the following link: http://www.ebay.com.au/sch/Suspension-Steering-/33579/i.html?_nkw=Brumby Met a Guy from Brisbane Australia at a car show.He said that Brumby's are still pretty easy to find there as well as parts. Not sure it's a perfect match yet. I'll keep you posted, Thanks! Quote Link to comment Share on other sites More sharing options...
ihscout54 Posted November 21, 2015 Share Posted November 21, 2015 Just use the ac delco part #s in those links. Quote Link to comment Share on other sites More sharing options...
Bratmobile Posted November 22, 2015 Author Share Posted November 22, 2015 Thanks IH Scout!~ Confirmed with shop that you provided the right parts & part #'s. At present no distributor is carrying them (that I could find) Contacted ACDelco directly to see if they could help. I'll keep you posted. Thanks again! Quote Link to comment Share on other sites More sharing options...
Bratmobile Posted December 1, 2015 Author Share Posted December 1, 2015 Found both parts at North Coast Subaru.Should be arriving in a day or two Quote Link to comment Share on other sites More sharing options...
