1995-1997 Subaru Legacy L Wagon KOEO Test
trying to figure out one of several things.
Vehicle:1995-1997 Subaru Legacy Wagon L w/AT & AC
Condition: KeyOn EngineOff Self Test
Beeps / chimes: 5 times
These bulbs are all still on after system/bulb test completes:
Check Engine
AT Oil Temp
Oil
Battery
Brake
What could be going on here??
Recently had a P0400 code. needed some EGR/ BPT work.  Code Cleared.  May still have clogged pipe(s), head, etc.
CEL (nor do any of the others) do not appear after the engine started.
Recently had a Drain & Refil of Dextron III ATF
Brake Master Cylinder replaced recently. Front Brakes 25% (4mm) Rear: 7mm
Other work that needs done:
Rad Hoses
all belts
Front brakes
Axle Boots
Power Steering Pump rebuild (leaks)
minor engine leaks (needs new gasket set)
