weslito2 Posted November 24, 2015 Share Posted November 24, 2015 I'm a novice, so bear with me. I changed the battery recently on my EA71. I noticed that the lights and the heat get stronger when I press the gas. Is this a voltage regulator issue or an alternator issue? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
john in KY Posted November 25, 2015 Share Posted November 25, 2015 Sounds normal to me. At idle the lights/heater motor get just 12 volts off the battery. Race the engine and the alternator kicks in and now around 14V flows to the lights. Quote Link to comment Share on other sites More sharing options...
weslito2 Posted November 25, 2015 Author Share Posted November 25, 2015 Thank you. Is there anything that can be done to keep it more consistent? Quote Link to comment Share on other sites More sharing options...
hatchsub Posted November 29, 2015 Share Posted November 29, 2015 What are you idling at? If your idling at 750 or so kick it up to 800 or 850 with the idle adjust screw on the carb. See if that helps. Might also want to clean all your grounds and electrical contacts under the hood to make sure your getting all your voltage. 1 Quote Link to comment Share on other sites More sharing options...
weslito2 Posted December 1, 2015 Author Share Posted December 1, 2015 I'm not sure what the idle is now. I didn't intend to screw with the carb since I will be replacing with a Weber this month. Quote Link to comment Share on other sites More sharing options...
