iamthevieve Posted November 28, 2015 Share Posted November 28, 2015 Hello. I'm new here making my first post I just bought a 1995 Legacy to replace my 2000 Outback that's having head gasket issues for the third time in three years. Anyway, the new one has some issues that I was curious about. First, it needs a new alternator. Can I use the one that's in the Outback or will I need to buy one? Second, the Legacy is having minor overheating issues. As in it starts heating up when I go up hills, but the needle never tops out and it will cool down once I'm over the hill. Please please tell me this is an easy fix. I'll scream if I end up with another head gasket issue. Quote Link to comment Share on other sites More sharing options...
Suzam Posted November 28, 2015 Share Posted November 28, 2015 Not sure about the alternator, you can cross reference the part numbers and see if they match. A couple of things you can check on the heating issues: Replace the old radiator cap with a new Stant cap.Replace the thermostat with a ginuine Subaru one NOT aftermarket. If you even think the antifreeze is old or diluted, drain it and put fresh in when you change out the thermostat. Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 29, 2015 Share Posted November 29, 2015 I would also add that you should check to see that the fan(s) are running. Start the car, turn on the a/c at least 1 fan should run. Let it idle, the other should start when the temp gets around half guage. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 29, 2015 Share Posted November 29, 2015 Check the coolant level. Get a rebuilt alternator from the dealer. There was a recall on those years ago and they are available rebuilt for about $70 from the dealer. 1 Quote Link to comment Share on other sites More sharing options...
mikaleda Posted November 30, 2015 Share Posted November 30, 2015 Overheating issue, I would check coolant level first but there's a good chance you need a new radiator. Get one online they are about $100-$125. Quote Link to comment Share on other sites More sharing options...
