Lakesong Posted November 28, 2015 Share Posted November 28, 2015 Passenger side cv gone bad on my 1995 legacy auto trans. Pulled out of my parts car a 97 manual trans legacy. Are these interchangable. The 97 looks larger, shaft diameter thicker and joints look beefier. Are these interchangeable?. Also when I removed cv axle from the working 1995 the splined shaft came out of tranny followed by tranny fluid. Doesn't appear damaged so I just pushed it back in. But before I proceed wanted to verify if I have a bigger problem here or anything special needs to be done to avoid a bigger problem. Quote Link to comment Share on other sites More sharing options...
mikaleda Posted November 28, 2015 Share Posted November 28, 2015 It will fit, but it will have a vibration in at stop in gear. The Manuel trans has a slightly different DOJ cup than the auto IIRC. Quote Link to comment Share on other sites More sharing options...
mikaleda Posted November 28, 2015 Share Posted November 28, 2015 (edited) Just read the other half of your post. The spline shaft that attaches the C.V. to the transmission should not be coming out. If it just fell out when you pulled the axle out it will probably still work, but i would say it does need to be taken care of sooner than later. the cv axel may not be cuplrit eaither is their any damage to the boot or any play? Edited November 28, 2015 by mikaleda Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 28, 2015 Share Posted November 28, 2015 Just a heads up. Trans fluid should NOT come out of the 4eat front diff. If trans fluid (red in color) came out, you have an internal seal bad. If gear oil (black) came out you're in good shape Quote Link to comment Share on other sites More sharing options...
Lakesong Posted November 29, 2015 Author Share Posted November 29, 2015 Oil that came out is dark brown. Gear oil? How to check? Also cv is definitely shot boot torn, tons of play. Quote Link to comment Share on other sites More sharing options...
mikaleda Posted November 29, 2015 Share Posted November 29, 2015 Oil that came out is dark brown. Gear oil? How to check? Also cv is definitely shot boot torn, tons of play. Dark brown would be gear oil which is what you should be seeing. And if the CV is shot for sure and the car was still running like that it will probably still function once everything is back in place. I wouldn't venture far enough to say its neccisarilly safe that way though. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 29, 2015 Share Posted November 29, 2015 Was the circlip still on the end of the stub when it popped out? If the circlip is gone you need to get a new circlip. Larger axle is probably aftermarket. They always have larger joints. Not always a good thing either. It'll fit and work, but may cause a vibration, may also start clicking soon. Front diff uses 80w-90 gear oil. Dipstick is on the passenger side of the trans. Quote Link to comment Share on other sites More sharing options...
mikaleda Posted November 29, 2015 Share Posted November 29, 2015 Was the circlip still on the end of the stub when it popped out? If the circlip is gone you need to get a new circlip. Is a circlip all that holds those in? Cause I've pulled the Axel out the doj cup before when trying to remove a stubborn Axel and those stubs are super solid. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 29, 2015 Share Posted November 29, 2015 Yep, just a circlip. And yeah they're tough to pop out because you're not supposed to remove the stub to remove the axle. On manual trans there's actually a C-clip/snap ring on the inside so the stubs can't be pulled out. 1 Quote Link to comment Share on other sites More sharing options...
Lakesong Posted November 29, 2015 Author Share Posted November 29, 2015 Clip still on shaft. Quote Link to comment Share on other sites More sharing options...
Lakesong Posted December 3, 2015 Author Share Posted December 3, 2015 I can't find dipstick for gear oil. I'm looking on passenger side of tranny but can't find. Quote Link to comment Share on other sites More sharing options...
Lakesong Posted December 4, 2015 Author Share Posted December 4, 2015 Output shaft won't go all the way in. Splines engage but only about 1/4in. I'm sure c clip is preventing sliding on the rest of the way. Do I just drive it on? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 4, 2015 Share Posted December 4, 2015 Insert the stub with the opening of the circlip pointing down. It ask helps to coat the clip with grease to hold it somewhat centered. Tap it with a hammer a few times to get it to seat. 1 Quote Link to comment Share on other sites More sharing options...
