Wanting to upgrade my wheels and tires.
classifieds on the Forums - post a WTB (want to buy) someone may have some wheels laying around. (here, subaruoutback.org, NASIOC, etc.)
you will need to confirm a few things for maximum possibility of problem-free driving - what size tire can you run with no rubbing or brake caliper interference, what wheel size that mounts to, can you find a good looking wheel that size that has the correct offset, is hub centric and is the right bolt pattern.
I wish I knew specifics about a 97, but likely someone here will.
there 'may' be a thread over at NASIOC called "what wheels fit my car" or similar.
Also, tirerack.com and I think also Discount Tire , have online shopping systems that allow folks to load a picture of their car model, then 'try on' pictures of different rims. That might be fun.
Edited by 1 Lucky Texan
The largest tire that will fit w/o rubbing or rolling fenders is 225/45/17. Keep the wheel offset from 48 -55 deg.
Caveat; they will not give you great traction in snow.
If possible, use your std wheels for a dedicated snow tire and either an all season for the 17 or a three season tire.
The ride is good.
See:ttp://www.rimsntires.com/specspro.jsp
O.
  • Like 2
7" rim. Though you could use a 7 1/2
What I found is that you have to play with the pressures to get the ride you want. Forget 30/32. Way too soft and lets the sidewall flex too much in aggressive cornering.
I now have Continental Contact All Seasons, and have had Bridgestone KDW. I wound up with 38/36. Used Blizzak for winter  on  16" rims and use 34/32
O.
Edited by ocei77
