mjvieceli Posted February 10, 2016 Share Posted February 10, 2016 Hi guys, Upon deciding the stage 2 wasn't enough, I have decided to look at getting a bigger turbo and the supporting mods to go with it. Research hasn't lead me anywhere productive and I have run into the problem of knowing if a turbo will bolt on or fitment treatment is required. I originally leaned towards a blouch td05-18g but later found out it wont fit. Is there a list of turbos I can find anywhere that have power ratings and are known to fit this model forester? Thanks! Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted February 11, 2016 Share Posted February 11, 2016 The most common upgrade is the vf52 from the 09-14 wrx. You can use any of the sti fitment turbos if you are planning to go to a front mount intercooler, or some of the aftermarket tmics are able to accommodate that style turbo as well. Any turbo that is made for the 05-09 legacy gt or 09-14 wrx is a direct fit for your Forester. But if you plan on running more than 17-18psi you will need to upgrade the intercooler, they like to separate the end tanks from the core at those boost levels. Quote Link to comment Share on other sites More sharing options...
