I have been donated an EA82T from a 86RX to go in my Brumby/Brat,
Apparently it has a split in the block (it let coolant out the exhaust),
I have the heads off and all looks good, where should I look for this crack when I split it open?
Has anyone heard of this happening?
Cheers Guys
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
EA82T Block split
Started by
Matty B
, Jun 03 2004 12:04 AM
4 replies to this topic
#1
Posted 03 June 2004 - 12:04 AM
#2
Posted 03 June 2004 - 12:11 AM
Coolant into the exhaust you say? Sounds like a cracked head to me..... have the heads pressure tested just to be sure. They are very prone to cracking, and especially in the exhaust area's. Even if it IS the block, still have the heads checked as they are notorious for cracks, and it would be a pitty to not find out till after assembly.
#3
Posted 03 June 2004 - 01:03 AM
Apparently it was using a little coolant on highway trips, only when running hot, and then all of a sudden steam and smoke from the exhaust and it was shut straight down. Where on the heads do they crack normally?
#4
Posted 03 June 2004 - 01:25 AM
I have had head gasket blow and still look half way decent.
knowing these motors I would guess head gasket. not the case.
GD is correct too. get the heads checked out.
#5
Posted 03 June 2004 - 02:11 AM
Normally a small crack between the valves is common. But if the crack continues up into the exhaust port it usually means the crack goes into the water jacket. Having the the heads welded is costly in some areas. The last estimate I had several years ago was $150US. It could be more or less where you are. I think if the block had a crack, you would be losing more than water.
