mcp260399 Posted March 18, 2016 Share Posted March 18, 2016 1993 Subaru Loyale AWD Wagon (SPFI) with no spark condition. Tried new distributor, coil/power transistor assembly and ECU(used). 12 volts at both positive and negative coil connections which seems odd. Car was at dealer for repair and they couldn't fix it for lack of accurate electrical system diagram. Engine wiring diagram in FSM is functionally correct but many of the wire colors don't match. Any suggestions would be much appreciated... Quote Link to comment Share on other sites More sharing options...
Dee2 Posted March 18, 2016 Share Posted March 18, 2016 So, you have power going into the distributor but no power coming out of the distributor ? Quote Link to comment Share on other sites More sharing options...
mcp260399 Posted March 19, 2016 Author Share Posted March 19, 2016 The voltages on the 4 wires going in/out of the distributor (which has the crank angle sensor in it) are: white: 6V red: 12V green: 6V black: 0V Quote Link to comment Share on other sites More sharing options...
mcp260399 Posted March 20, 2016 Author Share Posted March 20, 2016 Went the the procedure in the FSM for a no start condition and no +/- 5V voltage change is being seen by the ECU from the crank angle sensor so the FSM says its a bad sensor. However, the distributor (with new crank angle sensor) has been changed out twice and still no +/- 5V signal to ECU. Quote Link to comment Share on other sites More sharing options...
Dee2 Posted March 20, 2016 Share Posted March 20, 2016 (edited) My memory is weak, but I think there are posts in this forum about distributor wires and the colors. Since you mentioned changing distributors it's possibly the color connections may be off. See this link for partial discussion. There are likely more posts on the subject. http://www.ultimatesubaru.org/forum/topic/148648-help-with-93-loyale/?do=findComment&comment=1246915 hope this helps Edited March 20, 2016 by Dee2 Quote Link to comment Share on other sites More sharing options...
mcp260399 Posted March 20, 2016 Author Share Posted March 20, 2016 That was an excellent suggestion. I reversed the green and white wires and now I'm getting spark. Car still doesn't start so I'll go back through the timing procedure especially since the distributor has been taken out multiple times. Thank you very much.... Quote Link to comment Share on other sites More sharing options...
