things done so far -
new brakes all around,
new timing belts
new NGK plugs
new dist. cap
new plug wires
new fuel filter
changed out coil bracket (bad ignition amp)
swapped out fuel tank
swapped fuel pump, but going back to original one as the new/used one doesnt work...
car acts like it has a major short somewhere - turn key, get a loud click, then power dies completely. power resets itself after several minutes with key turned off. checked all grounds, battery connections, fuses and fuseable links under hood - where do we look next??????????????????
