wduzak Posted April 23, 2016 Share Posted April 23, 2016 I'm going to try and recharge air conditioner on my 99 Forester. I've looked at youtube videos and it looks pretty simple, but I did read a note about overcharging. Apparently if you only measure low-side pressure you can overfill. Is it necessary to measure high side as well? Any suggestions on kits? Looks like I can get them fairly cheap on ebay. Any tips or cautions? I'm not an idiot but I lack the mechanical skills and knowledge that most of the guys on this site have. Thanks Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 23, 2016 Share Posted April 23, 2016 Assuming the AC still works, but just isn't blowing cold, usually adding one 12oz can of refrigerant will bring it up to proper pressure and have it working again as it should. IIRC the refrigerant capacity on that year should be only about 15-19oz. If there's any question of how much to add, you can generally start with a half can, then monitor the center vent air temperature with an AC thermometer. (Couple $ on amazon) when the air temp is around 45-50°f you're pretty close to optimal charge level. Be sure it is set to recirculate with the fan on full speed. If the AC has stopped working, generally adding one full 12oz can of refrigerant will get it to start working again, then you may need anywhere from 1/4-1/2 a can to get it to full charge level. Again, add refrigerant slowly and monitor the vent air temp and you'll get it pretty darn close. 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 23, 2016 Share Posted April 23, 2016 lots of info here; http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/43428-diy-c-air-conditioning-leak-refrigerant-repair-5-less-15-minutes-less.html easiest is often as said above, (if repairs have been made and the systems is empty) put in the volume the system requires. Quote Link to comment Share on other sites More sharing options...
wduzak Posted April 23, 2016 Author Share Posted April 23, 2016 Thanks very much both of you. Quote Link to comment Share on other sites More sharing options...
Bushwick Posted April 24, 2016 Share Posted April 24, 2016 You can rent an AC charge kit from Auto Zone. It's technically "free" to rent as they only put a hold on your card until it's returned. I had a hell of a time getting mine charged (95' Legacy) correctly and it's still finicky at times as it might be freezing the sensor (forget what it's called) behind the glove box. I suggest charging on a warm (not hot) day and cross your fingers it'll blow cold when temps are really hot. Other cars just top off and they go cold, not this one. Quote Link to comment Share on other sites More sharing options...
