musubk Posted April 27, 2016 Share Posted April 27, 2016 I have an 86 BRAT and it seems to sit much higher in the rear end. I put a 2 inch lift in the front and that basically leveled it out. It also seems very stiff in the rear, as if it's oversprung. Is there a way to tell if a previous owner has clocked the torsion bar up? I've never tried adjusting it, but if I could determine it was adjusted up, I'd clock it back down and add some lift blocks to regain the ride height. Quote Link to comment Share on other sites More sharing options...
skishop69 Posted April 27, 2016 Share Posted April 27, 2016 My Brat has never been reclocked though I did do it once in the past to one of my previous Brats. Gen 2 Brats have about an inch and a half rake to them which you can bump to around two by adjusting it. If the front springs are weak or adjusted all the way down, it'll look that way. If the rear had been reclocked to lift it, it wouldn't just be stiff, it'd be like riding in a brick. All the Brats ride still in the rear. It's just torsion bar flex and there's nothing you can do to change that. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted April 27, 2016 Share Posted April 27, 2016 It's just torsion bar flex and there's nothing you can do to change that. I wouldn't say that unless you want to keep the rig bone stock. You can swap 3rd gen suspension under it so it has rear struts which would be fairly easy to do when doing a lift kit. You could also swap to a ej suspension or put in solid axles. Quote Link to comment Share on other sites More sharing options...
musubk Posted April 27, 2016 Author Share Posted April 27, 2016 (edited) I wouldn't say that unless you want to keep the rig bone stock. You can swap 3rd gen suspension under it so it has rear struts which would be fairly easy to do when doing a lift kit. You could also swap to a ej suspension or put in solid axles. It just so happens I have a 3rd gen parts car, maybe this is what I should do. How do you 'break' the torsion bar so you don't have the EA82 springs adding to the torsion bar rather than replacing it? Edited April 27, 2016 by musubk Quote Link to comment Share on other sites More sharing options...
silverhelme Posted April 27, 2016 Share Posted April 27, 2016 Undo and remove the adjustment bolt in the center which leaves the bar to act as a sway bar of sorts. Quote Link to comment Share on other sites More sharing options...
