Rave Posted May 2, 2016 Share Posted May 2, 2016 Hi, Has Subaru fixed the problem with head gasket failures on the new( present ) 3th generation 2.5L unturbo engines.Thanks for all your help. Quote Link to comment Share on other sites More sharing options...
mikec03 Posted May 2, 2016 Share Posted May 2, 2016 Subaru has used the terms first, second, etc generation in different ways so I have lost track of what they mean. If you are asking about the FB engine, which has been on the outback from 2013, then the answer is in all probability they have solved the problem. 1 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted May 2, 2016 Share Posted May 2, 2016 (edited) better off using years than "generation" as said. all EJ25 engines have headgasket issues to varying extents and failure modes. FB25 so far don't have issues but there hasn't been significant time for them to show issues yet either. the redesign and I think coolant not passing between heads and block give it a good chance of being less problematic if we want to guess. Edited May 2, 2016 by grossgary Quote Link to comment Share on other sites More sharing options...
