93 loyale warning lights came on
All of my warning indicators (Battery, AT oil temp, Parking brake, no CEL) came on. At first they were very dim and flickering but then fully lit after a couple minutes. Also, the other day I go to start my car after driving at highway speeds for 20 minutes and my battery was dead. I tested my alternator and it is putting out 14 volts and my battery is accepting the charge and has been fine for the last 4 or 5 days. Any ideas on what this could mean?
Sounds like alternator dieing. It might be intermittent.
My experience with more than a few is that original ea82 alternators get to around 150,000 miles and one of the brushes wears out. Other things also, but that one is like clockwork.
Would not hurt to check the connections from the main out to the fusible link box and battery also.
Ok, I will have it bench tested. It is the original and the car has around 170k so I'm sure it's time for a replacement. I originally took it to be bench tested but the parts store I went to didn't have the right harness for this alternator. They did test the battery and said the load amps checked out but the volts were a little low.
Thanks for your help fellas
Update: Over my weekend I opened the hood to take the alternator out and found that the belt was very loose. Apparently I didn't tighten the bolt down enough. :huh: Anyway, I removed the alternator and took it in to be bench tested and it passed. So I guess everything is fine for now. I still can't explain why my car battery randomly died after driving the car and it seems to be fine now? Gremlins I guess. Anyway thought ya'll would like to know.
All of my warning indicators (Battery, AT oil temp, Parking brake, no CEL) came on. At first they were very dim and flickering but then fully lit after a couple minutes. Also, the other day I go to start my car after driving at highway speeds for 20 minutes and my battery was dead. I tested my alternator and it is putting out 14 volts and my battery is accepting the charge and has been fine for the last...
ha ha ha I had the same trip.. except for me I zapped my alternator by crossing the batt cables... didn't think much of it ... i drove for 7 days then the lights started flickering... i checked every connection to the motor, chassis and srter..then it wouldnt even turn over,i took my Alt in and it failed even though my meter said it was charging 13-14 lol it was weird! Anymore I always disconnect my batt even if I'm replacing my wiper blades JUST FOR THE HELL OF IT! LOL!
  • Like 1
