Change the thermostat with a Subaru OE or equivalent design like Gates 34012.
Check inside the radiator for any buildup in the cores.
Check the outside fins of the radiator for any dirt/leaves/other crud stuck in it.
Fans running constantly can keep the thermostat partially closed all the time and cause coolant to run full flow through the heater core all the time.
Coolant constantly runs through the heater core anyway, but the flow is almost stopped when the thermostat is fully open the way it should be.
Possibly the fans were not turning on at all before, so the PO wires them to run all the time. May be due to a bad temp sensor.
