dp213 Posted May 23, 2016 Share Posted May 23, 2016 I have confused myself (easily done????). I have a 95 2.2 and it has no pullies on it. I have a couple pullies laying around and not sure which is for the 2.2. i am trying to figure out the cam pullies. I have 2 for the left cam, 1 has 2 timing contacts on the back and the other has 7. Any ideas. The only one I have for the right is plastic. Are the right hand plastic different between the early 2.5 and the 2.2. Thanks Dp Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 23, 2016 Share Posted May 23, 2016 Need the 7 tooth pulley for the left side. Should be able to use the 2.5 plastic pulley on the right as long as it doesn't rub the rear timing cover. The other metal pulley will also work. Quote Link to comment Share on other sites More sharing options...
dp213 Posted May 23, 2016 Author Share Posted May 23, 2016 Sweet, thank you. Quote Link to comment Share on other sites More sharing options...
winginit Posted May 23, 2016 Share Posted May 23, 2016 i think it also matters if the car is AT or MT the stubs on the back are for the censers to read the timing Quote Link to comment Share on other sites More sharing options...
dp213 Posted May 23, 2016 Author Share Posted May 23, 2016 It's a manual and the 2.5 that came out was a manual Quote Link to comment Share on other sites More sharing options...
winginit Posted May 23, 2016 Share Posted May 23, 2016 i forget what one you need, but one has a couple and one has several,tabs on the back. a quick search will give you your answer im sure. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 23, 2016 Share Posted May 23, 2016 Auto/MT no difference. Around 00-01 they changed the cam from 7 notch to the 2 notch wheel. Crank went from 6 notch to 20ish small notches with a large solid section to mark TDC. Quote Link to comment Share on other sites More sharing options...
