coolhandluke Posted May 26, 2016 Share Posted May 26, 2016 Hello my 92loyale with dr swap Is in trouble!!! I am out of town and car broke down on girl friend...from what she has told me- Car has no power to wheels like it's not in gear. Stick "swims" into first but just revs. No power. Happened suddenly while she was driving. If you have experienced this I would appreciate the advice. Quote Link to comment Share on other sites More sharing options...
jono Posted May 26, 2016 Share Posted May 26, 2016 you get a nuetral in between FWD and 4WD hi, and another between 4WD Lo maybe it got pulled partially into 4WD? good anti theft measure 1 Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted May 27, 2016 Share Posted May 27, 2016 If a front CV broke it will do the same. Does the speedometer go up when she revvs it in gear? Does it drive if she shifts it into 4x4? If so, probably a busted front CV or stripped hub. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 27, 2016 Share Posted May 27, 2016 Besides a Busted C.V. Joint and a 4WD lever placed in between gears; the only third thing that could be Happening, is a Clutch fail... but even if the Clutch disk slips, the car had to move a little. Let us know what happened; Kind Regards. Quote Link to comment Share on other sites More sharing options...
l75eya Posted May 28, 2016 Share Posted May 28, 2016 So to sum it up, could be a stripped out hub in the front. Put it in 4wd if it's 4wd and it will move. Could be stuck between 4wd gears. Major sure the shifter is properly engaged in either fwd, 4wd, or 4lo. Could be the clutch. Could also just be your shifter linkage came loose. 1 Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted May 30, 2016 Share Posted May 30, 2016 Stripped hub is my guess... i had it happen on my GL. Quote Link to comment Share on other sites More sharing options...
jono Posted May 30, 2016 Share Posted May 30, 2016 i'd say this thread be dead in the water by now itself, girl run off with the hero of the day .... 2 Quote Link to comment Share on other sites More sharing options...
coolhandluke Posted June 15, 2016 Author Share Posted June 15, 2016 Ha wow. Well the CV for sure. It really just sh** out everywhere. What a mess. She said the steering got a little weird and but could see no visual problem. So drove on if further untill complete blowout / disconnect. How dangerous can a axle failure be? Seems a little wild! This was a new axle I had just installed. Ol Loyal is really not likin the 2" lift. I like it VVV . Really need to get that crossmember/ subframe droppped. Quote Link to comment Share on other sites More sharing options...
DaveT Posted June 15, 2016 Share Posted June 15, 2016 Bigger angles, [from the lift] probably makes more stress on the joints. I don't think the inner joint fail would cause any dangerous steering effect. Outer, probably feel more. I had an outer boot fail once, and didn't discover until the joint was already ruined, and clicking. Drove it for a while longer due to not having time, until it got bad enough to cause shimmy in the steering wheel. I have not had one fail completely. As far as I know, I have all OEM axles. I have always rebuilt them, some saved from previous cars, some bought used a scrapyards and rebuilt. Quote Link to comment Share on other sites More sharing options...
wagonist Posted June 16, 2016 Share Posted June 16, 2016 Is the other CV joint on that shaft a "floating" joint? Every inner front CV I've ever seen is more square to allow the shaft to move in & out slightly to allow for the suspension movement. If it doesn't have this on at least one of the joints, it'll pull out (like what's happened to you) over bumps or turning. 1 Quote Link to comment Share on other sites More sharing options...
ukkiwi Posted June 24, 2016 Share Posted June 24, 2016 Is the other CV joint on that shaft a "floating" joint? Every inner front CV I've ever seen is more square to allow the shaft to move in & out slightly to allow for the suspension movement. If it doesn't have this on at least one of the joints, it'll pull out (like what's happened to you) over bumps or turning. I was thinking this. That's an odd looking inner joint. Doesn't look like there would be much play in that. Quote Link to comment Share on other sites More sharing options...
