Alternator Replacement PT#14585
Yo Fellow Subaru Lovers!
Had to get a new alternator from Autozone.
Ordered the Identical part number as removed from the 88 GL-10 Turbo.
The New unit appears to be larger and will not tighten to produce tension.
Just to the right of the Lower mounting bolt it seems to be rubbing the Ac Compressor Mount.
Anyone else had this issue when attempting to reinstall a OEM Replacement Alternator.
I am using the same belt and also have swapped to the old pulley to see if that was the issue.
 Starting to think maybe the Chassis of the alternator was redesigned..... maybe its wider.... Old Unit was returned for the 11.00 core.
If there is anything I am missing or you need hit me up.
Brokenneck
RIchland Washington.
