EA82 Map lights
I just took the map lights out of my GL and installed them in my loyale. The swap was a breeze, mostly just screwing it together and a little bit of cutting. The bracket for the lights is there in the Loyale, even with predrilled holes. All you have to do is remove the trim on the drivers side A pillar on both cars, cut the hole in the headliner, disconnect the power wires from under the dash, and fish the wires through on the other car. There is even the appropriate connector for the power leads under the dash. It's an easy 20 minute job that makes a useful improvement to the car.
