wakingtowinter Posted June 9, 2016 Share Posted June 9, 2016 wtdash - or anyone else who has done this work around: which is the IAC hose that needs to be T'd into? I plan on using my EJ18 EGR intake on the non-EGR EJ22 that is about to go in. The IACV looks a bit different on the EJ18 and from wtdash's write-up I can't quite tell what to T into: Quote Link to comment Share on other sites More sharing options...
wtdash Posted June 21, 2016 Share Posted June 21, 2016 (edited) Hi, Suggest sending a PM my way for faster response. Can't see the pic @ work, but if the IAC has a hose that goes to the air intake (and is not a coolant line), that should work. I have no experience w/the EJ18. Edit: I don't see a hose off the IAC, but that 1.8 IAC is very different than the 2.2/2.5's. But all you need is a hose that runs into the intake to the throttle body, so you could 'make one' that plugs into it. Just don't use the PCV or Breather as you'll be blowing blue smoke out the exhaust. GL, TD Edited June 21, 2016 by wtdash Quote Link to comment Share on other sites More sharing options...
