lichen Posted June 19, 2016 Share Posted June 19, 2016 1998 legacy outback, cooked the seal retainer cap/welded it to exhaust cam. Took head out, burned #1 cylinder exhaust valve replaced&milled head. New head gasket and belt and tensioner +new cam seals and crank seal. Couldn't get the motor mounts in, (rocky going and long day), so tried shortcut. Started engine, thought rocking a bit would bring the engine forward a quarter inch. Engine dies. Repeat. Maybe it won't run w/out exhaust manifold bolted up? Quote Link to comment Share on other sites More sharing options...
mattslote Posted June 20, 2016 Share Posted June 20, 2016 (edited) I had the same thing happen with a friend's '08 Forester. Make sure the airflow sensor is plugged in and at least have that part of the intake manifold assembled. Edit: Disregard. Just saw the other thread on the same topic. Edited June 20, 2016 by mattslote Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 20, 2016 Share Posted June 20, 2016 confirm timing, line-up marks and do a tooth count. Quote Link to comment Share on other sites More sharing options...
