Legacy2010 Posted June 24, 2016 Share Posted June 24, 2016 Just had my engine changed on legacy 2010 and since i have no more lights, low beam high beam tail light illumination lights dash lights dome light dash clock.the only working lights are brake lights and flashers. I've checked the fuses and the relays all work fine. Any ideas? Quote Link to comment Share on other sites More sharing options...
montana tom Posted June 24, 2016 Share Posted June 24, 2016 Check the wiring near the battery, look for smaller disconnected wire going to positive terminal . Quote Link to comment Share on other sites More sharing options...
montana tom Posted June 24, 2016 Share Posted June 24, 2016 Could also be a ground wire , that was disconnected for engine removal. Quote Link to comment Share on other sites More sharing options...
wtdash Posted June 25, 2016 Share Posted June 25, 2016 (edited) Not sure Where it is, but sounds like a fusible link? Probably where MT Tom pointed to. GL, TD Edited June 25, 2016 by wtdash Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 26, 2016 Share Posted June 26, 2016 If you have verified that power is getting to the proper fuses for the lights then check the ground connection going to the light switch. The switch uses a ground connection to turn on the lights so make sure that is making good connection to the switch. Quote Link to comment Share on other sites More sharing options...
