donuteater Posted June 25, 2016 Share Posted June 25, 2016 (edited) I replaced the front wheel bears and I am starting to believe that the rears may be bad. The noise goes away when I engage 4wd. It sounds like I'm dragging an aluminum bat across the concrete. Has anyone had similar noises? Sorry, I'm dumb and can't embed... Edited June 25, 2016 by donuteater Quote Link to comment Share on other sites More sharing options...
Len Dawg Posted June 25, 2016 Share Posted June 25, 2016 I don't hear it... if anything I would probably check the drive line, disengage 4wd drive try to shake it.. Quote Link to comment Share on other sites More sharing options...
Norcalbratcap Posted June 25, 2016 Share Posted June 25, 2016 Best guess is That metalic eccoing sound is from your rear driveline I'd start there and block the car off the ground safely and try to pinpoint the sound. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 25, 2016 Share Posted June 25, 2016 To embed a Youtube's video here, see ~► http://www.ultimatesubaru.org/forum/topic/152891-recurrent-question-how-to-share-photos-on-your-posts/?do=findComment&comment=1287611 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 25, 2016 Share Posted June 25, 2016 ... and can't embed... I've embedded your video above. I don't hear it... Also I can't hear a clear thing to be sure what's wrong... ... if anything I would probably check the drive line, disengage 4wd drive try to shake it.. Best guess is That metalic eccoing sound is from your rear driveline I'd start there and block the car off the ground safely and try to pinpoint the sound. That's good advice; check the driveline, let us know the Results. Kind Regards. Quote Link to comment Share on other sites More sharing options...
donuteater Posted June 27, 2016 Author Share Posted June 27, 2016 (edited) I will, I made another video on the way home from work. I am off the next couple of days so I can try to troubleshoot. Thanks for the help with the video. it worked!!! I will let you know if I find anything. I checked the front diff and tranny, both are full of fluids. I will check the rear diff fluid level tomorrow as well as put the car on stands and check for noises. Edited August 13, 2016 by donuteater 1 Quote Link to comment Share on other sites More sharing options...
donuteater Posted August 13, 2016 Author Share Posted August 13, 2016 The noise was coming from the driveshaft. Thanks for your suggestions and sorry for the delay. I have another addition to the family, a 1992 Loyale Sedan FWD that I have been driving instead of my wagon. Donut Quote Link to comment Share on other sites More sharing options...
