1992 loyale won't start after warmed up
did you check for any computer codes ? If no codes then possible causes are:
-vapor lock, next time it fails to start try removing fuel cap off gas tank to see if it helps
-fuel pump/ relay affected by heat
-coolant temperature sensor
-alternator / voltage regulator being affected by heat
Edited by Dee2
  • Like 1
