pbilt Posted July 21, 2016 Share Posted July 21, 2016 (edited) There are 2 engines one is a carb 165lbs compression other is spfi 150 lbs compression the I know the spfi has a higher compression ratio but would the carb make more power anyway since it has more compression mine is carbed I'm swapping manifolds if I go with the spfi Edited July 21, 2016 by pbilt Quote Link to comment Share on other sites More sharing options...
el_freddo Posted July 23, 2016 Share Posted July 23, 2016 I'm not sure I'm following you 100% on what you've said. The higher compression reading will generally be the better engine. The SPFI to me would be the better way to go for factory power, reliability and economy. But it's not just an intake manifold swap. You'll need the ECU, the wiring loom, intake manifold, other odds and ends for emission gear and probably the exhaust Y pipe, or at least a bung added to your exhaust for the O2 sensor. CheersBennie Quote Link to comment Share on other sites More sharing options...
silverhelme Posted July 24, 2016 Share Posted July 24, 2016 I think what he is asking is if he will have more power using a carb if he uses the SPFI block with stock carb setup. The short answer is yes but probably not enough to really notice. I would probably pick the motor with the best, most even compression and the least mileage. Best way to get the extra power is to swap in the complete SPFI setup including wiring and ECU. Quote Link to comment Share on other sites More sharing options...
pbilt Posted July 27, 2016 Author Share Posted July 27, 2016 (edited) silverhelme thank you I'm not going for a big power upgrade just wondering what the Healther block out of the 2 would be they were both the same price just the spfi was 85 miles closer they were both Close to even compression on all 4 I went spfi just Because it was closer and yes I put the carb intake and distributor on it Edited July 27, 2016 by pbilt Quote Link to comment Share on other sites More sharing options...
