bgambino Posted July 26, 2016 Share Posted July 26, 2016 So twice now I have done rear brake jobs on my or my familys Subaru and ran into a weird issue In this case it was 2003 impresa rs Last was probably 04 wrx of my son So I mount the rotor and tire and as I start tightening the lug nuts, the tire gets harder and harder to spin...until it totally will not spin at all Take a look at the pic of the new rear rotor....that raised lip on the inner edge of the drum opening (for the shoes)...as I tighten the lugs....this rams into the face plate surrounding the brake shoes It took me awhile to figure out what was wrong the first time....this time I recognized the problem immediately Take them off and grind the raised lip down flush with the rotor disc surface Autozone rotors.....I doubt they gave me the wrong parts but.....? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 26, 2016 Share Posted July 26, 2016 may need to readjust your parking brake shoes first, retract them for install and then expand them back out so they're adjusted properly with the new rotors? or it sound like you may be saying something is wrong even beyond that? i'd keep the OEM rotors if you can or get a set from a yard, ignore all the crazy rust. i'm still rolling 260,000 miles on my original rear rotors, i never replace them, the stock rotors are robust pieces of metal. i resurface if i have to but i've never had to on a rear rotor...well i probably have once or twice and am forgetting but it's rare. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 26, 2016 Share Posted July 26, 2016 this "lip" - if it's on the new ones and not on the old original rotors then it's probably no supposed to be there? i'm not seeing it clearly on the picture...any side by side shots? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 26, 2016 Share Posted July 26, 2016 Autozone rotors... Could be your answer there... 2 Quote Link to comment Share on other sites More sharing options...
