Fatenarr Posted August 7, 2016 Share Posted August 7, 2016 I keep getting a misfire on cylinder 4 and I put in new plugs and wires and I'm still getting a misfire under load typically going uphill. Next I'll try the coil. My main question is how do I know which cylinder is # 4 in case I need to do an injector? Quote Link to comment Share on other sites More sharing options...
golucky66 Posted August 7, 2016 Share Posted August 7, 2016 My buddies Impreza 97 had a misfire when under load, the coil was bad. For some reason I can't remember which one it is, it's a rear cylinder (closer to the seats) and whichever plug is further back. i'm pretty sure its passenger side Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 8, 2016 Share Posted August 8, 2016 #4 is left-side, rear. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 8, 2016 Share Posted August 8, 2016 Most likely on of the following: Injector Coil pack Timing tensioner is on that side Tight valves - but I think 96 is still HLAs so that would not be possible Quote Link to comment Share on other sites More sharing options...
ocei77 Posted August 8, 2016 Share Posted August 8, 2016 (edited) If you have a 2.2 (since it's not an OB),, the last choice is a burnt exhaust valve, O. Edited August 8, 2016 by ocei77 Quote Link to comment Share on other sites More sharing options...
