New member new to owning a loyale
I have owned a couple subarus before this one but i just picked up a 94 loyale. Im pretty clueless when it comes to this one im used to the newer models haha but i am trying to learn as i go and would like some advice as i dive into it. Also id like to know where everyone is getting their parts from its hit or miss at the parts stores ive begun to realize. Thanks for reading any advice im all ears.
Hi!
Look though the older generation threads.
Unless you know things were well taken care of -
Typical things to consider.
Radiator condition - fine fins still attached to the tubes.  No leaks / cracks.
Cooling system should be watched closely, at least until you are certain all is sound.
All 7 coolant hoses should be replaced if they are unknown / or original.
Coolant should have very little to no air [sharply squeeze the upper radiator hose, listen for the jiggle pin, and gurgles]
Recovery tank should be at the full mark, and not change day to day - check cold.
One of the alternator brushes typically wears out at about 150K miles.
Timing belts and idlers - replace around 50K miles.
Check the CVJ boots for split open, better to catch them before they are ruined, as the aftermarket ones are not so good.
Check all the other typical wear things, like brakes, etc.
