Flat4Power Posted August 22, 2016 Share Posted August 22, 2016 Hello ladies and gentlemen. I'm trying to fix my horn right now and need a little advice. The guy I bought the car from changed the steering wheel and did not properly hook up the clock spring to the steering wheel. My question for you is that I know the yellow connector from the click spring is for the air bag (because I had to fix that ), but what is the white connecter for? Is that the horn connection? If so I should be able to fix this quick....if not, what is it? I'm nervous to just jump the wires and test it out like a cowboy. Thanks for the help Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 22, 2016 Share Posted August 22, 2016 White connector inside the wheel is horn/cruise switch. Power wire comes from the horn relay and should be green with a red stripe. That splits, one side provides power to the cruise switch. (If installed) Other split goes to the horn buttons or contacts on the wheel. Quote Link to comment Share on other sites More sharing options...
