dp213 Posted August 22, 2016 Share Posted August 22, 2016 A friend of mine said he took his 2000 outback to the shop because it started to overheat. The shop said he has transmission fluid in his radiator. If that is the case and there is a hole in the radiator wall next to the tranny cooler part of it, wouldn't there also be coolant in his tranny? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 23, 2016 Share Posted August 23, 2016 Not necessarily, but he should definitely check it. Trans fluid is under much higher pressure, so can be forced out of a small pinhole or split in the cooler. When the engine turns off and the trans stops pumping the pressure in the radiator pushes the opposite way and can close the hole which prevents coolant pushing through. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 23, 2016 Share Posted August 23, 2016 how positive are they it's actually leaking? that's not very common to have happen. as an illustration, picture scaled rust where it's not exactly a hole, the fluid finds and seeps through slowly and can vary quite a bit in how it does it. 1 Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 23, 2016 Share Posted August 23, 2016 (edited) Is the coolant nasty-looking? Any signs this car has been run with straight water and no antifreeze? I'd be suspicious of an internal head gasket leak and a possible wrong diagnosis about the trans fluid. But, if there's any doubt, one test could be to disconnect the lines to the cooler and temporarily connect them together. Run the car a little and watch for; A. leakage of coolant from the coil. B. overheatingalso, the thermostat MUST be OEM-style, with the larger wax capsule.Don't run the transmission too much if you feel there's coolant mixed in the fluid!while pricey and a little bit of a hassle, fluid samples could be sent to Polaris or Blackstone labs. Edited August 23, 2016 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
