tanner93loyale Posted August 25, 2016 Share Posted August 25, 2016 My passenger side window on my loyale wint roll up. Checked the fuses already and took the door panel off to see if anything was unplugged and i still cant get it to go. Any other ideas or do i need a new motor? Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 25, 2016 Share Posted August 25, 2016 If the contacts in the switch on the door card are corroded that could be your problem. The window motor might be corroded too so it might work if you take it apart and clean it. The first thing i would try is jumping the window motor straight from the battery to see if that's your problem. If it works you could have a broken wire from the door opening and closing. Quote Link to comment Share on other sites More sharing options...
tanner93loyale Posted August 25, 2016 Author Share Posted August 25, 2016 If the contacts in the switch on the door card are corroded that could be your problem. The window motor might be corroded too so it might work if you take it apart and clean it. The first thing i would try is jumping the window motor straight from the battery to see if that's your problem. If it works you could have a broken wire from the door opening and closing. How do i test it with the battery? Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 25, 2016 Share Posted August 25, 2016 By hooking up a negative and a positive wire to the battery to jump it. The motors only have 2 wires so depending on what way you jump them they will make the window go up or down. Quote Link to comment Share on other sites More sharing options...
tanner93loyale Posted August 26, 2016 Author Share Posted August 26, 2016 By hooking up a negative and a positive wire to the battery to jump it. The motors only have 2 wires so depending on what way you jump them they will make the window go up or down. Tried testing the window switch with my test light and the switch is fine. Still need to just the actual motor but i got a new motor from pick in pull and i hooked it up to the switch and it didnt work as well. So either both motors are bad or the wires that power the motor are fried? Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 26, 2016 Share Posted August 26, 2016 Quote Link to comment Share on other sites More sharing options...
tanner93loyale Posted August 26, 2016 Author Share Posted August 26, 2016 Its not saying you posted anything just your name and a white screen Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted August 26, 2016 Share Posted August 26, 2016 Its not saying you posted anything just your name and a white screen Weird i posted a video i found that showed how to test the motor. Quote Link to comment Share on other sites More sharing options...
tanner93loyale Posted August 26, 2016 Author Share Posted August 26, 2016 Weird i posted a video i found that showed how to test the motor. I jumped the motor and the window went up so the motor is good just somewhere electrical is cutting out somewhere i guess. Hopefully nothing to bad. Quote Link to comment Share on other sites More sharing options...
