Radiator drain plug size?
I can't answer that.... what I have done with nearly every radiator I've had is tap the hole with a 1/8 or 1/4" pipe tap (depending on which will fit) , and screw in a real petcock with a short hose on the other end. Now I can catch all of the ccolant, instead of it getting all over the frame, etc.
Thanks for the suggestion. I hadn't thought of just tapping out the hole.
