Engine Swap Into a 2003 2.5 Outback
Welcome to the USMB,
Matt is 100% correct.
I'd add that I personally would avoid using the shortblock from that '98. They were usually susceptible to overheating from the failed head gaskets and may not have much life left. There's a lot of interchange info on here and the web....remember, Imprezas and Foresters used the same engine, so anything from '99-'05ish Impreza/Forester and '00-'05 Legacy can be used w/minor work (use your '03's intake manifold).
Edited by wtdash
