mcbrat Posted September 6, 2016 Share Posted September 6, 2016 Okay, got a 88 DL wagon with an EA81 in it. I think I have the right spots on the ea82 harness for the temp guage, but I'm not sure if the 2 blade gauge on the ea81 will work with the ea82 harness? thoughts? Quote Link to comment Share on other sites More sharing options...
ihscout54 Posted September 20, 2016 Share Posted September 20, 2016 Im going to assume by "gauge" you are refurring to the sender. The senders should be interchangeable between EA81/82's. So you could find a single terminal sender and install it, or figure out which terminal on the sender is for the gauge. The 2 terminal senders were for feedback cars one terminal was for the gauge the other for the ecm. Without looking up the info I could not tell you which is which. So in other words might have to experiment with terminals. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted October 10, 2016 Author Share Posted October 10, 2016 the 88DL was originally SPFI. I still need to get the FSM so I can look at the wiring diagram.... Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 26, 2016 Share Posted October 26, 2016 ... I still need to get the FSM so I can look at the wiring diagram .... Download it from page five of my "BumbleBeast" build thread, whose link is on my signature below. Kind Regards. 1 Quote Link to comment Share on other sites More sharing options...
mcbrat Posted December 11, 2016 Author Share Posted December 11, 2016 thanks JesZek. Looks like the "stock" sender was a single wire, but I was able to get my ea81 2 wire to work fine. I hooked it up to the wrong wires 5 years ago 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted December 11, 2016 Share Posted December 11, 2016 thanks JesZek ... You're welcome! I'm glad to know that you fixed it. Kind Regards. Quote Link to comment Share on other sites More sharing options...
