TheBubbaJoe Posted September 6, 2016 Share Posted September 6, 2016 So here i am 2 years later. i had found a 1978 brat for 1200$ 2 years ago but was out bid at the time. i never thought id come across another brat in the midwest. recently i stumbled on another 1978 brat for 1000$ but i got him down to 700$. this Brats history: this 1978 model brat was bought by the owner from a dealership in the late 70's. it enjoyed light country driving for 100,000 miles until the owner became to old to drive it. it was then parked in there lawn for two years where mother nature could bite at its steel panels. other than body rust and interior wear in tear the engine runs fine. when i looked at it with the owner we opened the hood and poured gasoline into the carb. it started right away after sitting for 2 years. i didnt a good look at the frame or the floor but im hoping its not a rusted beyond repair under it. half the exhaust has been eaten away well any way heres the pics. i only have one bucket seat for the rear. the driver window is gone need a new one. the rear fender arches are probably rusted beyond repair and will need new panels. so does anyone have any advise for this project? any passing words of wisdom. Quote Link to comment Share on other sites More sharing options...
TheBubbaJoe Posted September 6, 2016 Author Share Posted September 6, 2016 its pretty nice that they left the bed roof on it prevented the bed from rusting Quote Link to comment Share on other sites More sharing options...
80brat Posted September 7, 2016 Share Posted September 7, 2016 Lift up the carpet and check floor from top and bottom, check your wheel wells, I think you can pull the ash tray out and peek under the dash to check for wire damage from rodents, check in portland craigslist, there is a 78 junk brat for parts and you can look elsewhere for a door window, are a few ideas Quote Link to comment Share on other sites More sharing options...
TheBubbaJoe Posted September 8, 2016 Author Share Posted September 8, 2016 i'm picking it up this weekend . ill start out with your advise thanks. this weekend ill put more pictures up of the car condtions and progress Quote Link to comment Share on other sites More sharing options...
80brat Posted September 9, 2016 Share Posted September 9, 2016 PM sent Quote Link to comment Share on other sites More sharing options...
TheBubbaJoe Posted September 10, 2016 Author Share Posted September 10, 2016 Quote Link to comment Share on other sites More sharing options...
TheBubbaJoe Posted September 10, 2016 Author Share Posted September 10, 2016 had a little time to wongleflute around with the Subaru today. fuel was not being pumped so i replaced the inline pump and the filter. it still was not pumping fuel. i need to tinker waiting for the subaru shop manunal to come via UPS Quote Link to comment Share on other sites More sharing options...
TheBubbaJoe Posted September 11, 2016 Author Share Posted September 11, 2016 figured out the fuel pump today. the car started right away and idled like it was 1978 again. drove it around the block transmission is good and the 4wd works. the drive highlighted some critical issues that need to be fixed. -only the driver side front break works. e-brakes work -the front driver side drive shaft is rubbing the steering linkage making the wheel jerk as if it was torque steer. good things that became apparent: - the AC completely works - the radio still works -the signals all work along with the dashboard lights aka most the factory wiring has not become chewed away by rats. Quote Link to comment Share on other sites More sharing options...
TheBubbaJoe Posted May 7, 2017 Author Share Posted May 7, 2017 anybody know if its possible to get fiberglass or aluminum molds of the body panel? Quote Link to comment Share on other sites More sharing options...
Naked Buell Posted May 9, 2017 Share Posted May 9, 2017 Haven't seen or heard of it. Have to become good friends with a welder or start learning yourself. That is what I did. Also something to check is the gutter in front of the windshield that catches all the water, just below your wiper assemblies. Make sure you clean those out. They have a issues with stuff getting stuck down there and holding moisture and creaturing rust. Pull the spare tire out and the two metal pieces of the body mold together where the spare tire sits and you will be able to see if you have any rust. Quote Link to comment Share on other sites More sharing options...
Rust Posted May 9, 2017 Share Posted May 9, 2017 Whats up with the wallpaper treatment to the Bedcap? I guess the PO was going for that country home vibe, or maybe he dated Martha Stuart? Quote Link to comment Share on other sites More sharing options...
moosens Posted May 9, 2017 Share Posted May 9, 2017 Bubba , looks like a good project you have there. Now that Martha doesn't own it anymore it should be a great little buggy. Where NB mentioned for sure. All early Subarus suffered that area. Don't be afraid to remove your dashboard. Another area is the front fenders up top. You might want to take those off and remove any foam tape stuff you might see. Subaru put that there for squeak suppression. But it holds water and rusts those fender tops even in dry climates. I just parked my old 78 4WD wagon probably for life now. The brake lines were a big issue. Protect them as best as you can. Good luck. Quote Link to comment Share on other sites More sharing options...
spicypeanut Posted May 20, 2017 Share Posted May 20, 2017 Best of luck to you, this one looks like it could be a mixed bag. Some great potential here. Quote Link to comment Share on other sites More sharing options...
