Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
1988 Gl Wagon Upgrade Help
Started by
WagonBoy
, Jun 09 2004 04:26 PM
11 replies to this topic
#1
Posted 09 June 2004 - 04:26 PM
First of all i beleive the engine in the 88' is an EA-82 correct me if i'm wrong, what kind of upgrades can i put into it or what would be a good replacement motor that would bolt up to my current 5spd tranny? Anyone be able to estimate a cost for an engine swap...? Just looking into it, I havn't done anything yet...
#2
Posted 09 June 2004 - 04:31 PM
Forget the engine; get yourself a lift kit and tires
That's what I did to my '88 and im very happy!
Is the engine fine or are you looking for a swap cuz its toast?
#3
Posted 09 June 2004 - 04:35 PM
The heads are cracked and currently we are going to replace them, i'm just looking for some easy upgrades for a little extra guts for offroad
#4
Posted 09 June 2004 - 04:59 PM
two words:
Delta Cams.
search around here for more info. Cheap power and you'll be right ther in the motor while replacing the heads.....
garner
Delta Cams.
garner
#5
Posted 09 June 2004 - 09:26 PM
Delta cams... anyone give me some links to where i can get them if not i'll just look around, i'll be replacing the heads... and cams if i can before the lift and tires unfortunately
#6
Posted 09 June 2004 - 09:38 PM
#7
Posted 09 June 2004 - 09:49 PM
Their order for page is down, or its a broken link... shall i call?
#8
Posted 10 June 2004 - 12:20 PM
Some info from board members that have installed them
http://www.ultimates...lta cams thread
yes, easiest to call them. I believe Jerry is the fellow I talked to. They generally have a set ready to ship and you can send your's in as cores. This is great because of the lack of down time. I had my motor apart and sent my cams to be reground. Took about 6 days with shipping both ways.
garner
garner
#9
Posted 10 June 2004 - 12:52 PM
That sucks the engine is blown
Guess the lift and tires are on hold heh. Good luck on the rebuild!
#10
Posted 10 June 2004 - 01:58 PM
should i send mine in or order whole new ones?
whats the best way to go?
shall i get new lifters also...?
I read that other thread and it said that some that just cleaned the used lifters well used them and they didnt do anything in the area of ruining the engine
Also i've got the EA-82 engine
#11
Posted 10 June 2004 - 02:08 PM
If you have the time, send your's in. That way you know the cams and carriers are used to each other and tolerances should be maintained.
As for lifters, mine were beautiful, your's are probably the same. I believe you can send them in and they will inspect/correct if needed. It is a good idea to re-install the lifters in the same location as you removed them, same with the hydraulic lash adjusters(HLA). Also when you remove the HLAs, store them submerged in oil or ATF so they stay pumped up until you re-install.
gluck
garner
gluck
garner
#12
Posted 10 June 2004 - 04:17 PM
Thanks to everyone who replyed so quickly and for all the help, i plan on sending mine up w/ the rockers to inspect them i'm also calling Delta Cams today + calling the guy i'm buying the heads from. Big day and thanks again for all the help. I'll keep posting updates on the project
