5 speer D/R swap: What are you folks using for a shift boot?
Obviously you've cut the floor to fit it in so you'll have to modify a factor console to work or buy an aftermarket boot kit. I modified the shelf the shifter mounts to as well as the linkages so it sits in the same hole which I believe is what most do. Jerry sells a kit with all the pre-fabbed parts to install so it goes through the factory hole..
