I put a 93 2.2 in a 99 outback this week. I used an intake from a 96 2.2. Everything is done and it runs great, but it threw the p0106 code. The 99 had a map sensor sensor and only 1 tube running to the intake. The 96 intake had 2 tubes running to the map sensor.
As it sits I have put the map sensor from the 96 in to accommodate both tubes. Should I put the 99 map back in and plug off 1 of the tubes.
About 8 of these type of swaps and this is the first time I have ran into this. Any help would be great.
Thanks
Dp
