95 ej22 swap, no compression on right bank
Hey fellas, my 95 ej22 that is in my 86 has ZERO compression on cylinders 2 and 4. I installed new head gaskets and valve seals.
The timing belt seems to be installed properly, all notches lined up, 44 and 40.5 teeth! Even if it were off a tooth or two, I should have some compression am I right?
The left bank reads 160 psi for both cylinders.
I'll take the valve cover off soon and check the cam, springs, clearances etc...
Any ideas? It seems like a valvetrain issue, I haven't done a leak down test yet, but it seems like a moot point considering zero compression.
Is there a way to install the cam wrong or something? I know the pulley can't be!
That's what I was thinking since both cylinders are reading zero. I tried one tooth to the left and one tooth to the right, same result. However, I van feel air moving when I stick my finger in the spark plug holes, but it's nothing like the left, you can barely hear it on the right.
I'll do a leakdown test tomorrow to see what is going on when the piston(s) are at tdc.
It's a little frustrating because the engine runs good for having two dead cylinders, so I think the wiring part of the swap is ok at least!
So close yet so far :P I cannot wait to drive this thing!
Edited by sparkyboy
I used the notch on the tab for the sensor, as well as the notches on the cam gears that line up with the notch on the plastic cover behind it. I thought maybe the crank wasn't lined up right, that it was maybe on the wrong stroke even though the marks were lined up, but I think if that were the case none of the cylinders would have compression. I'm doing a leakdown test tomorrow, so I'll see what that's about!
I'll double check the compression on 1 and 3, thanks caboobaroo!
Edited by sparkyboy
Well boys this is an embarrassing one, but I found the problem. Get ready to laugh at this one!
After removing the valve cover I could hear the compression escaping from the exhaust side. I removed the rocker arms and checked the HLAs (fine) and rotated the engine some more just for grins and I could STILL hear air moving in and out! I'm really confused at this point, so I just bit the bullet and pulled the engine out.
Once the cylinder head was off I couldn't believe my eyes! I, drunkenly I must assume, got the exhaust and intake valves mixed up!!! Stupid mistake, I know but I'll get busy with the valve spring compressor tomorrow and a new head gasket and get it all back together.
I'll let you guys know how she runs soon, then onto the next little problem that I am certain will pop up! ;P
Thanks for your help!
