golden gordon Posted September 25, 2016 Share Posted September 25, 2016 My wife's 92 L series wagon broke down and she wanted to tow it to the wreckers . I'm trying to save the old girl (car not wife). Wifey said she was changing from 4th to 3rd gear when the motor died, no loud noises. In trying to diagnose the problem, before I began stripping the motor down, it turned over just wouldn't start. Had no spark, checked distributor- rotor button not spinning. Checked timing belts-left hand side (distributor side) not turning, pulled it down and discovered a stripped timing belt. How much if any damage can this cause? Any help or suggestions from similar experience gratefully appreciated before I go wasting money on new timing belt kit. Quote Link to comment Share on other sites More sharing options...
ClassySoob Posted September 25, 2016 Share Posted September 25, 2016 A freind of mine had a belt snap on his 86. He had damage to valves and some lifters. Quote Link to comment Share on other sites More sharing options...
ClassySoob Posted September 25, 2016 Share Posted September 25, 2016 The worst that could happen would be damage to the head or pistons. I've heard of pistons shattering, but luckily I haven't gone through any of that... Knock on wood Quote Link to comment Share on other sites More sharing options...
Uncle Ed Posted September 25, 2016 Share Posted September 25, 2016 I've striped the teeth of on one. Grabbed a set of belts from the auto parts store, put them on and drove it to work the next day. The EA82's are supposed to be a non-interference engine. So my advice to you is read the write ups on doing the timing belts, pick up a timing belt set. When your done, you can hand her the keys back with a smile knowing that it's good for another 50k miles. Ed 2 Quote Link to comment Share on other sites More sharing options...
golden gordon Posted September 25, 2016 Author Share Posted September 25, 2016 I will check the cam wheel, oil pump drive, idler sprocket and tensioner to make sure there not seized then put the new belts on, do the timing and see what noises it makes when I turn it over. Quote Link to comment Share on other sites More sharing options...
Len Dawg Posted September 25, 2016 Share Posted September 25, 2016 (edited) My belt broke nothing happened, don't get confused when you put the belts on.. line up the center of III on the fly wheel align the driverside cam dot upwards but give it a smige before because when ya let the tensioner go it will maybe over shoot it, rotate till ya get to the center of III driverside cam dot should pointing down at the other mark. Then align the passenger side cam dot up...release tensioner... rotate entire system until the flywheel is the center of the III and driverside should be up and passenger side down... connect the green plugs driverside by fuel filter and set your timing.. good to go... Edited September 25, 2016 by Len Dawg 1 Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 25, 2016 Share Posted September 25, 2016 I've had more than a few break. Put on new belts, new idlers and tensioners, good to go. It's a non interference engine, so valves and pistons do not meet. 3 Quote Link to comment Share on other sites More sharing options...
superpoo93 Posted September 25, 2016 Share Posted September 25, 2016 I've had more than a few break. Put on new belts, new idlers and tensioners, good to go. It's a non interference engine, so valves and pistons do not meet. Yep, do as Dave T said. These cars are so easy to work on, and there is ton of info here. Let the wife know you may spend some time repairing it, and $60-$100 for timing belt/pulley kit(Ebay). Just not having a car payment and not paying a crap load for registration is golden for me. You cannot hurt these cars unless you abuse them..... maintenance is key, and they go everywhere! 1 Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 25, 2016 Share Posted September 25, 2016 Check this out: ~► http://www.ultimatesubaru.org/forum/topic/48359-timing-belt-procedure-ea82/ Kind Regards. 1 Quote Link to comment Share on other sites More sharing options...
DaveT Posted September 25, 2016 Share Posted September 25, 2016 Buy a good quality kit, not the cheapest. Change every 50 to 60 k miles to be extra safe. Far cheaper the the timing belt service on the newer ones, even though the change interval is about double the miles. I only use oem for the ej and newer engines. Number is thing to stay on top of is the cooling system. Checking level frequently, don't wait for the temperature gauge to tell you it's bad. 2 Quote Link to comment Share on other sites More sharing options...
Numbchux Posted September 26, 2016 Share Posted September 26, 2016 Non-interference. No head damage. I've probably had a dozen or more EA82 timing belts break on me. Even drove one home with the passenger side belt broken. When I was delivering my blue lifted wagon to sell it, I had the driver's belt break, and I installed a new one on the side of the road in about 10 minutes (running without belt covers). If the teeth are stripped off the belt, it's probably because the cogged idler seized. I've had that happen. 1 Quote Link to comment Share on other sites More sharing options...
moosens Posted September 26, 2016 Share Posted September 26, 2016 Yeah , it's non interference so no damage. Buy the good kit with pulleys and get another 100k out of it. I know budgets can restrict what we "think" we should do , but really you should do it right and change all pulleys , water pump too if you hadn't had it done , and reseal or replace the oil pump. While you are there you'd be foolish to not also change the front main seal (crank) and cam seals too. It'll take you all day if you've never done this but with all the write ups here you might do it in half a day or less. It's extremely painful to do any job and then realize shortly that you "should have done this or that while I was in that deep". Reseal and good belts and pulleys. Do NOT buy the bottom line crap from car parts wiz or and other cretin selling on eBay. For non factory you would do great with Gates. 2 Quote Link to comment Share on other sites More sharing options...
ClassySoob Posted September 26, 2016 Share Posted September 26, 2016 You know thats one thing that slips my mind about these motors, is the non-interference engine. That's what makes them even better. I was thinking of other engines, my apologies. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 27, 2016 Share Posted September 27, 2016 (edited) new pulleys and belt and you're golden, can be done in well under an hour, easy job. leave the covers off for easy access/save time. Edited September 27, 2016 by grossgary Quote Link to comment Share on other sites More sharing options...
Rust Posted September 29, 2016 Share Posted September 29, 2016 (edited) I bet the lower cog wheel on the drivers side seized causing the teeth shredding. It is very close to the exhaust pipe. I had one seize before. I fabbed up a heat shield when I put the new belts and new cog wheel on. Edited September 29, 2016 by Rust Quote Link to comment Share on other sites More sharing options...
subnz Posted September 29, 2016 Share Posted September 29, 2016 Agree shouldn't be any piston / valve damage - had a similar experience after replacement toothed idler pulley seized stripping left new T belt a year later. Quote Link to comment Share on other sites More sharing options...
wagonist Posted October 3, 2016 Share Posted October 3, 2016 You should be lucky & just need to replace the belt. the belts are supposed to last 100 000km, but Subaru Oz got a large number of warranty claims when the cars were new of belts breaking at 80 000 or so, so the service interval was dropped to 75 000km. watch out undoing the bolts for the cam covers. the captive "nuts" are only embedded in the rear plastic cover, so they tend to "spin" & therefore you can't undo the bolts. Soak them first. also suggest undoing the aircon (you can unbolt it & swing it off to the side without undoing the lines) & alternator to give you room. Remove the radiator also to give you clearance. As suggested, do the water pump while it's all apart. Quote Link to comment Share on other sites More sharing options...
franbev Posted October 4, 2016 Share Posted October 4, 2016 Does this apply to the EA81 engine too? Quote Link to comment Share on other sites More sharing options...
DaveT Posted October 4, 2016 Share Posted October 4, 2016 EA81 doesn't have timing belts. Quote Link to comment Share on other sites More sharing options...
robm Posted October 4, 2016 Share Posted October 4, 2016 Chances are the outer covers will come off in pieces. They are the ones that have steel bolts screwed into brass inserts in the rear covers, that get frozen in place. The centre cover comes off easily, as it is screwed into the block, not brass inserts. I like to reinstall the centre cover, as it helps keep sticks, snow, etc., from getting jammed into the belts. The recommended change interval is 90,000 km (55,000 miles), but I find they don't last as long without the covers. Change them at 75,000 km /45,000 miles, or else it will let your wife down again. 1 Quote Link to comment Share on other sites More sharing options...
golden gordon Posted October 6, 2016 Author Share Posted October 6, 2016 Thanks for all the great posts, mission accomplished... the suby lives again .... and wifey thinks I am amazing Quote Link to comment Share on other sites More sharing options...
sparkyboy Posted October 7, 2016 Share Posted October 7, 2016 (edited) My wife's 92 L series wagon broke down and she wanted to tow it to the wreckers . I'm trying to save the old girl (car not wife). Saving your car would be more fun than saving the wife anyway! :-) Edited October 7, 2016 by sparkyboy Quote Link to comment Share on other sites More sharing options...
DaveT Posted October 7, 2016 Share Posted October 7, 2016 Directly from my 1986 factory service manual: EA82 Timing belt replacement is due at 60 months or 60,000 miles, whichever is first. Directly from my 1990 factory service manual: EA82 Timing belt replacement is due at 52.5 months or 52,500 miles, whichever is first. Somewhere a long while back, I came across a TSB about lowering the interval for the timing belts. Which makes sense, because I have been driving EA82s since 1988 and never had a timing belt make it to 60,000miles. Quote Link to comment Share on other sites More sharing options...
robm Posted October 7, 2016 Share Posted October 7, 2016 The owner's manual here in Canada specifies 90,000 km, which is 55,000 miles. I have had them last 90,000 plus a bit, with covers on. I have never had them last to 80,000 km without covers. 70- 75,000 is as much as I can get, it seems. But as the covers usually come off in pieces, they are hard to put back on. And I prefer to run with the centre cover on, as it comes off easily, and helps keep oil, antifreeze, sticks, etc. out of the moving bits. Quote Link to comment Share on other sites More sharing options...
DaveT Posted October 7, 2016 Share Posted October 7, 2016 the trick to keeping the covers was to get them before they were rusted. Reassemble with anti seize, and they come off easy. Quote Link to comment Share on other sites More sharing options...
