ThosL Posted September 27, 2016 Share Posted September 27, 2016 I went to a local garage last week, among other things for some front end rattles I've been hearing; they said it is the sway bar that needs bushings, he said it doesn't undermine mechanical performance and there is a cheap fix. Quote Link to comment Share on other sites More sharing options...
golucky66 Posted September 27, 2016 Share Posted September 27, 2016 Yeah, the bushing tend to wear out over time and miles and the diameter of the hole gets better then the sway bar and so when you hit a bump the bar gets forced up and hits the bushing because it's not a tight fit anymore. Having play in the bushing does have an effect on handing of the car, but it effects the car more in a racing world then a daily driver world. They will just causing a clunking in the front end when you hit a bump. Quote Link to comment Share on other sites More sharing options...
ThosL Posted September 28, 2016 Author Share Posted September 28, 2016 OK, thanks for the insider info. Quote Link to comment Share on other sites More sharing options...
