crazyhorse001 Posted October 24, 2016 Share Posted October 24, 2016 Ok, so i'm in the process of making an xtgl/XT6 mashup. Both cars are fwd. I know i gotta Frankenstein the axles up front. Can i put the xt6 outer cv's on the fwd axles? As in pull the snap ring, and transfer the whole cv onto the axle shaft splines. Second, can i transfer the whole rear suspension subframe and all from the 6 to the gl? Or would it be better to just transfer the arms? Trying to gain the rear sway bar here. I know someone on here has to have done this at some time. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted October 24, 2016 Share Posted October 24, 2016 The rear subframe is essentially the same, minus the mount for the front of the rear diff. The swing arms are what the sway bar mounts to. Make sure to use 4wd rear struts with the 4wd swing arms unless you want a 2" lift. Quote Link to comment Share on other sites More sharing options...
john in KY Posted October 24, 2016 Share Posted October 24, 2016 Fairly sure CV axles from a 1st ben FWD Impreza are the way to go. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted October 24, 2016 Share Posted October 24, 2016 (edited) Fairly sure CV axles from a 1st ben FWD Impreza are the way to go. Those require some creativity with the inner wheel seal. I did some research on theoretical solutions and have posted it a couple times. CV axles are weird, the shafts change diameter and spline count with very little pattern. If it's ever had a reman axle put on it, you have zero prayer. A local friend of mine 5-lugged my old FrankenWagon with the PT4WD D/R (23 spline) trans in it, and he was able to create one good axle by swapping the 23 spline inner onto the XT6 shaft with what he had, but had to be several reman axles to get another combination that worked. Rear suspension crossmember is identical between the FWD XT6 and FWD EA82. Just swap the arms, it's easier. Edited October 24, 2016 by Numbchux Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted October 24, 2016 Author Share Posted October 24, 2016 I have some ej knuckles, would that make my axle search easier? 1 Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted October 24, 2016 Share Posted October 24, 2016 From my experience, and a few others on the forum, legacy/impreza axles are a bit too long to work in the ea82/xt6 platform without extending the control arm roughly an inch. Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted October 24, 2016 Author Share Posted October 24, 2016 Looks like I'll be seeing my buddy with an ea junkyard i know the 6 is on oem axles. Not sure of the ones in the gl. Hopefully he can hook me up. That means from here on out, i'll be remanning my own axles Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted October 24, 2016 Author Share Posted October 24, 2016 I know finding a fwd turbo trans is a looooongshot, so I'll do what i can with what i have. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted October 24, 2016 Share Posted October 24, 2016 I've used EJ axles/knuckles with XT6 control arms on 3 different cars (2 different sets of axles, 3 different sets of control arms, at least 3 different strut/spring setups) without any trouble. EJ knuckles/brakes with '93-'94 Impreza FWD MT axles and EA81 tie rod ends should be a bolt-in. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted October 24, 2016 Share Posted October 24, 2016 http://www.ultimatesubaru.org/forum/topic/122306-hybrid-axle-help-asap/ Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted October 24, 2016 Author Share Posted October 24, 2016 Sooooo long story short, i either need a fwd turbo, or xt6 trans to make my life easier. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted October 25, 2016 Share Posted October 25, 2016 Is the gl a 5mt? If so you can swap the stub axles to 25 spline stubs. Requires disassembling the transmission, but it's not a difficult job. Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted October 25, 2016 Author Share Posted October 25, 2016 Yep, but the xt6 is auto Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted October 25, 2016 Share Posted October 25, 2016 I have a bad mainshaft bearing ej 5mt up here I'll donate the stubs from if you're interested in doing it. Quote Link to comment Share on other sites More sharing options...
wagonist Posted October 25, 2016 Share Posted October 25, 2016 How is the XT6 being an auto relevant? The front diffs in auto & manual are the same width. As long as you find the correct spline count for the inner CVs for your driveshafts, you'll be sweet. BTW, the stubs from a 4wd gearbox should fit a FWD gearbox. It's only the back half of the trans that's different. Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted October 25, 2016 Author Share Posted October 25, 2016 So wagonist, you're saying i should be able to use the stubs from the 4eat in the 5mt? Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted October 26, 2016 Author Share Posted October 26, 2016 Its looking more and more like i should just do a rear disk swap and a 6lug conversion. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted October 26, 2016 Share Posted October 26, 2016 If you go that route I'll buy the 5 lug parts if you wanted to sell them. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 27, 2016 Share Posted October 27, 2016 Paul - I now own your old silver XT6 and I found out two nights ago it has EJ axles with XT6 hubs. The passengers side wheel bearing was shot. The other side looks to be an EJ axle as well. So if you want to risk/replace seals/bearings, EJ axles can work in an XT6 hub. So wagonist, you're saying i should be able to use the stubs from the 4eat in the 5mt? I think he meant stubs from 4WD to FWD - meaning both automatic, are interchangeable. auto's just pop out of the trans, MT's are integrated into the front diff. I have an XT6 MT if you want to make an offer that makes me want to pull it. lol Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted October 27, 2016 Author Share Posted October 27, 2016 I put those axles in that car. They're O'Reilly's parts. I had to go back 3x to get axles that fit! I have till spring to decide about 5 luggin my gl. I work outside, and i won't have weather much longer Quote Link to comment Share on other sites More sharing options...
wagonist Posted October 27, 2016 Share Posted October 27, 2016 No, I meant you could get the stubs from a manual 4wd to put into your FWD box to get a higher spline count. Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 3, 2016 Author Share Posted November 3, 2016 Ok, so barring the 5lug, how hard is it to swap rear disks to a fwd? While I'm at it I REALLY want the rear sway bar too. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted November 3, 2016 Share Posted November 3, 2016 Ok, so barring the 5lug, how hard is it to swap rear disks to a fwd? While I'm at it I REALLY want the rear sway bar too. About the same as a 4WD. The hubs, and maybe the backing plates, are unique to FWD, so it's best to have a FWD donor car. If you want the sway bar, you'll need the whole suspension arm. You could actually grab the whole trailing arm, bearing and brake assembly from a 4WD car. But then you'd need the 4WD shock. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted November 3, 2016 Share Posted November 3, 2016 That junkyard I pointed you to on Facebook has at least one fwd gl-10 turbo wagon in it. Last I laid eyes on it a few months ago it still had the rear disc setup on it. Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted November 3, 2016 Author Share Posted November 3, 2016 I'm assuming I'll need the master cyl as well, right? Quote Link to comment Share on other sites More sharing options...
