i need help on a 1982 wagon
7 replies to this topic
#1 sethpistol1
sethpistol1
    New User
  • PipPip
  • 15 posts
  • Spokane
Posted 10 June 2004 - 10:34 PM
can you put on a center lamp or head lamp on a 1982 gl wagon. if so where can i find one with the grill.
#2 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,192 posts
  • WA
Posted 10 June 2004 - 10:40 PM
Only if you dont have a/c. The cooler is in the way. If not, you wont need the grill, it can be cut to fit.
#3 sethpistol1
sethpistol1
    New User
  • PipPip
  • 15 posts
  • Spokane
Posted 10 June 2004 - 10:56 PM
where can you get them at because i don't have a/c and also how do you put it in there.
#4 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,192 posts
  • WA
Posted 10 June 2004 - 11:25 PM
Here is a article on the wiring.
http://usmb.net/repa...79.98068180.art
Might do some reading here, but most of the post were from Feb.
http://www.ultimates...?searchid=18052
#5 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,953 posts
  • Denver, Colorado
Posted 11 June 2004 - 12:32 AM
I have added a centerlamp on my 83 wagon with AC. Mine is a 4 headlight frontend so I have to chop out a stock grill cuz they didnt put the centerlamp option on the quad light cars.
What makes it not work?
I havent operated it yet but its bolted on and ready to be powered up.
#6 worknwood
worknwood
    USMB Regular
  • PipPipPip
  • 46 posts
  • Lake Almanor, CA 96137
Posted 11 June 2004 - 01:35 AM
My '82 brat came with the star emblem missing from the grill. When I found a "third eye" (center light) at pick 'n pull I took the works, grill, light, bracket, screws and wiring to the first connector. I also found an empty connector on my brat in the same place I disconnected from the doner car. It plugged right in. I also have ac, and have not tried it yet.
#7 Guest_taprackready_*
  • Guests
Posted 11 June 2004 - 10:30 AM
My 82 brat has AC and factory center light.
Bill
#8 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 11 June 2004 - 11:25 AM
here's a good diagram for doing the wiring with the DPDT switch....
Posted Image
