sadarahu Posted October 25, 2016 Share Posted October 25, 2016 I recently replaced 4 struts. When driving on bumps or over a pat holes still hear ratling noise. Month ago I replace 4 sway bars as well. I wonder what else could cause it or what would be the next to replace to improve suspension issues ? Subaru Forester 2007 (86k). ARTHUR Quote Link to comment Share on other sites More sharing options...
wtdash Posted October 26, 2016 Share Posted October 26, 2016 Hi, Rattling noise? Or thumps, clunks, etc? Rattling could be heat shields, exhaust or that plastic cover that is under the engine on some Subies? Td 1 Quote Link to comment Share on other sites More sharing options...
sadarahu Posted October 27, 2016 Author Share Posted October 27, 2016 thanks but those sounds are more like a suspension or stabilization. I checked the items you listed and do not think it is any of them. I drive long enough to hear the difference although I cannot exactly say which pat of the suspension. Checked the mufler and plastic shield see no problems. Quote Link to comment Share on other sites More sharing options...
AdventureSubaru Posted October 27, 2016 Share Posted October 27, 2016 Often as simple as something loose in the spare tire area or in the storage compartments. Can also be worn loose rear bushings. If you aren't feeling anything in the drive ability or steering it's not much of an issue. Car is nearly 10 years old so a little noise is commonplace Quote Link to comment Share on other sites More sharing options...
dp213 Posted October 28, 2016 Share Posted October 28, 2016 Have you replaced the sway bar end links? That has been the most common thing I have found to cause noise when hitting bumps. If the rubber looks weathered and cracked, replace them. Quote Link to comment Share on other sites More sharing options...
