Willow Posted October 27, 2016 Share Posted October 27, 2016 The HID low beam headlights on my 2010 Outback 3.6R are dim to the point of being dangerous. Despite mentioning this to the dealer every service, nothing has been done. Being now out of warranty, what steps can I take to improve the situation? I notice that the current model Outback has the same or similar lights, but are very bright. Any thoughts? Quote Link to comment Share on other sites More sharing options...
montana tom Posted October 27, 2016 Share Posted October 27, 2016 Sounds dangerous. Have you checked other 2010 cars to see if they are the same ? Daytime driving lights use less voltage in the hope your low beam bulbs will last longer, they are much dimmer. Could your car be somehow stuck in the daytime position ? Quote Link to comment Share on other sites More sharing options...
Willow Posted October 28, 2016 Author Share Posted October 28, 2016 Thanks for the reply MT. I'm not sure that my car has that feature, although it was the top of the line in 2010. How do I check, and what would be the remedy? Cheers. Quote Link to comment Share on other sites More sharing options...
DaveT Posted October 28, 2016 Share Posted October 28, 2016 That daytime light stuff started before 09. Are the bulbs in the HID failing? They have only so many hours that they can last. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 28, 2016 Share Posted October 28, 2016 I've never seen HID lights that I thought were too dim. normally they're obnoxiously bright. How long has this been a problem? HID bulbs do have a finite lifespan, after several years the light they start to burn at a lower temperature and the light they produce is less intense and of a more blue-ish/purple color. Quote Link to comment Share on other sites More sharing options...
montana tom Posted October 28, 2016 Share Posted October 28, 2016 Willow; Anytime your engine is running your daytime headlights will be on. Try this at night, If you turn on your headlight switch, low beams should get significantly brighter. If not something is wrong. Go back to your dealer to JUST to check the lights , no oil change no nothing , please fix my lights. You have them ,they started daytime running lights on the 2000 year group. Quote Link to comment Share on other sites More sharing options...
forester2002s Posted October 28, 2016 Share Posted October 28, 2016 Willow, I see that you are from Australia, where DRLs are not mandatory. Maybe your car has the DRLs? Do you still have weak headlights when the headlight-switch is all the way to 'ON'? Quote Link to comment Share on other sites More sharing options...
Willow Posted October 31, 2016 Author Share Posted October 31, 2016 Wow, thanks to you all for your replies. Let me answer your questions. Firstly, forester 2002s. You are correct about DRLs in Australia. Matter of fact, after checking on www.howsafeisyourcar.com.au I found that the 2010 Outback does not have DRLs even as an option. The order of lamp illumination is: first setting, parking lights. This illuminates small quartz lamps in the corner of the high beam housing. second: low beam headlights are on. Third and last setting is the auto function. In both setting two and three the HID low beam lighting is the same intensity. I drove the car last night and it may be my eyesight, but since I last drove at night, I believe that the low beam was even duller than before. So, F4me, you may be right about the lifespan and deterioration of the lamps, but these lights have been, to me, unacceptable since day one. Co-incidentally, I have to return the car to the dealer due to a recall about the wiper motor, so I will take your advice mt, and hit them up for it. Don't like my chances, as they did nothing while it was under warranty, so what would compel them to do it now. However, will give it a go. Will keep you all posted. Cheers. Quote Link to comment Share on other sites More sharing options...
