Head Compatibilities - 2.5 DOHC 96 & 99
The reason I am doing this is the old heads from the 96 have bad valves - one burnt off or it is missing a chunk.  No compression is the result.   So, I have the 99 heads which were already machined, just trying to save some money.  If I use the old head, I'm assuming it would need to get it machined plus have do the the valves.   If I do the valves I'm assuming I would need to have the seats lapped or what ever they do to match the new valves?
Any advice would be appreciated.  Based on the two responses, I'm not sure if I should use the 99 head.
Thanks!
Any idea if the valves in the (96-99)heads would be the same?  I know I can pull them out and compare - just curious if anyone would know off the top.  Also, what is the recommended prep on the block surface.  I use a sharp havy duty razor blade perpendicular to the surface and scraped off the gasket residue and wiped with brake clean.  Do I need to use scotch brite or something similar?
Thanks
When you start messing with head gasket thicknesses on overhead cam engines you are also playing with the cam timing. For instance many people use 97-99 ej25d heads on ej22e shortblocks for a budget low compression engine to turbo. They use 1.5mm thickness headgaskets instead of the 1.3mm thick ej25d gasket and it is enough to throw the cam timing slightly off. Most show about half a tooth out of time on the LH bank after the belt is tensioned and rotated a few times.
Most run pretty well, but there is a common complaint with almost all of them of a slight misfire feeling at idle and part throttle. Not enough to trigger a cel, but enough to feel.
Going from 1.3mm to 1.5mm also doesn't affect the combustion ratio that much, it drops it to 10.3:1 from 10.5:1. To get this particular hybrid back down into the 9.7:1 figure that the 97-99 25d has would require a 2mm head gasket, and at that point you're going to have issues with the timing belt being too tight to last very long.
Well, guess I'm gonna buy a valve, lap the valves/seats, news guide seals in and let er go.  No comments on clean-up for the block side of things?  Suggestions for getting the carbon build off?  The valves and the top of the pistons look nasty.
Thanks
Edited by xyzb
I check the head surface for flatness - it is in spec <.002 .  The head gaskets were replaced several years ago by the previous owner.  There are some light marks from the previous gasket.   Is there a need to resurface it?  Do you guys suggest coating the new MLS with Permatex Copper spray?
Thanks
i always resurface - i don't even care or measure for flatness because that's not the only point.  i want it clean and proper RA finish on an engine that's already prone to failing headgaskets with the OEM factory installed brand new parts.
you still have a great chance and high success rates without resurfacing too if you're in a bind for some reason, though you seem more than capable of just doing it yourself anyway:
http://www.ultimatesubaru.org/forum/topic/122588-diy-head-resurfacing-or-post-apocalyptic-machine-shop-techniques/
Newbie on the valve stuff - looking for guidance. This car is a winter beater, so I would prefer to not spend a bunch and use it as a learning project. Take a look at the exhaust valves. They are full of carbon, not sure if they are worth lapping or just buy new and try to lap the seats? I bought Permatex lapping compound and there is mention of different grits to start and finish with. I'm assuming these can be purchase or not needed? The intake valvues look good. Also, recommended solvent to clean them?
Thanks!
Exhaust seat with some lapping:
Exhaust
Intake:
Intake
Exhuast valves - no lapping and some lapping:
Exhaust Valves
Edited by xyzb
Thanks for all the info!  Just curious about the block side of things.   I pulled the head with the motor in the car.  How is the surface prepped and what would you use to ensure that the surface is good to go to install the new gasket?
Thanks!
