vwbuge Posted June 11, 2004 Share Posted June 11, 2004 I found an '87 XT today for $325. 115k and he says it runs good. Supposing it is not a turbo is this motor still fuel injected? DId they have carbed XT's? Will the motor from an auto bolt up? (just change the flywheel?) Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 11, 2004 Share Posted June 11, 2004 No carbed XT's. GD Quote Link to comment Share on other sites More sharing options...
vwbuge Posted June 12, 2004 Author Share Posted June 12, 2004 I talked to the not-so-local Subaru guy. (probably close to 100 Soobs in his backyard) He is about 40 minutes away. He told me probably just dirt in the carb. He told me to run it hard for a while. 70psi is normal in an older motor like that. (150,000) I think I am going to go with the motor I have. I need to install oil pump seals, rear main seal, water pump, thermostat and a few hoses. I will put it back in and see what happens.Now that I am thinking about it I used to have an old '84 wagon that did the same thing. I revved the hell out of it and then put my hand over the top of the carb until it almost died. I did that a few times and it sucked the dirt through and ran normal after that. I should dig out a pic of that wagon. One hot looker. Never seen another like it. It had factory air, sunroof, power windows and locks, cruise and digital dash. Quote Link to comment Share on other sites More sharing options...
WJM Posted June 12, 2004 Share Posted June 12, 2004 Again, no carbed XTs. Yeah, run some good good fuel injection cleaner thru it, like, 3 bottles/cans in 1/2 a tank. Run it WOT as much as you can. :devil: After all, thats how SUBARUs are designed, WOT all the time! Quote Link to comment Share on other sites More sharing options...
MilesFox Posted June 12, 2004 Share Posted June 12, 2004 you can put a carb motor in the xt, hook up the disty to the coil, and let all the mpfi harness hang loose. tach still works. swap in a carb fuel pump. Quote Link to comment Share on other sites More sharing options...
