Matt_J Posted November 28, 2016 Share Posted November 28, 2016 (edited) Hey Gang - I'm new to USMB - but I'm an old forum junkie all the way back to the the old alt yahoo days, anything from whitewater, FJ40 jeeps, skiing, and lately golf. So, as self-proclaimed forum fan I should know better than to fire up a new account and instantly ask a question that could be found through the search engine, right? Unfortunately I can't put the right search terms together to find anything, so here goes... Late model, 2013 Subaru Outback. I've been sick and parked it on Tuesday evening after work in the carport. Didn't drive it at all over the holiday and went out to crank it this morning and it won't turn over. Night time temps have dropped a little but we're pretty temperate for Oregon and are not getting much below freezing if at all. Sounds like a bad battery? Car is 3 years old, so I guess the battery could be out, but the starter is turning over great. I disconnected the terminals to let the cpu drain while running a battery charger on the battery. My battery charger is pretty beat, but the charge seems to be acceptable. After an hour of trickle charge and then an attempt to start it with the charger on "jump" mode, it still won't turn over. I'm no pro mechanic, but it sounds like it isn't getting fuel. If it was an older car or a lawn mower I'd probably disconnect the air box and blow starter fluid into the intake while someone else turned the key, but that doesn't seem like the best idea in a "new to me" car. Any help GREATLY APPRECIATED. I have AAA but don't really want to tow it to get it started if possible. Edited to Add: I'm finding some information about a defect in the Special Appearance Package starter button - my OB doesn't have the Special Appearance Package - just a normal old key with fob. Edited November 28, 2016 by Matt_J Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 28, 2016 Share Posted November 28, 2016 So the car is turning over just fine, that should mean it's not the battery. Need to read the check engine lights. An auto parts store can do a load test on the battery. Advance Auto, Autozone Napa, orielleys, go there and have it tested. They can also read trouble codes for free. Try jump starting the car with another vehicle. One very very common problem is post or terminals are dirty/corroded or loose. That would be odd on a 2013 but so is not starting. I've seen some mention of newer Subaru's around your vintage and newer having dead batteries, I'm not sure the cause or if that's just an artifact of Subaru's growth (selling more cars now, so therefore the same failure rates are more noticeable evne though theres no substantial change in reliability). But might be worth a look. 1 Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted November 28, 2016 Share Posted November 28, 2016 Does car crank, but no start?? Or, not crank at all? Have you turned on the head lights, and are they bright? With your beat up charger, maybe it is best to use jumper cables to know that you are getting good voltage added to the electrical system. Suggest you try that. 1 Quote Link to comment Share on other sites More sharing options...
Matt_J Posted November 29, 2016 Author Share Posted November 29, 2016 The positive terminal is a little corroded. I'll probably clean it and take the battery in for testing tomorrow. By all my normal standards the battery seems fine, lights are bright and the starter is turning over at full speed. Need to replace that old battery charger anyways, and honestly if it's just a bad battery that would be best case scenario. Unfortunate that the battery would only last 3 years / 36,000 miles, but I'm hearing that is becoming more normal these days. I'm more scared that it's a fuel problem i.e. pump. Should know more tomorrow. Quote Link to comment Share on other sites More sharing options...
DaveT Posted November 29, 2016 Share Posted November 29, 2016 If the starter cranks the engine at normal sppeed, the problem is not the battery. Quote Link to comment Share on other sites More sharing options...
Angry & Disappointed Posted November 29, 2016 Share Posted November 29, 2016 My 2011 Subaru Outback, with only 35,000 miles on it, only starts when it feels likeit. The battery is brand new, connections are strong, wires are clean andsound, starter cranks like a champ, but the car just won't start. This began shortlyafter the 30,000 mile servicing. The car usually starts in the morning, or if youleave it parked for seven hours or more. But otherwise, chances are it won’tstart. I have been stranded five times now over a four week period. I take the car to Stamford’s Subaru service center and they keep it for three days and then tell me theirdiagnostic computer says there's nothing wrong with it and to come pick itup. Last time I did, I ran into a neighbor with a new 2016 Outback, and shesaid she has exactly the same problem. She has had the dead car towed on aflatbed truck to Subaru Service four times. They told her it was her faultbecause she "wasn't driving it enough." No, seriously. Subaru Service told me my problem was very rare. Wrong -- justgo on a Subaru forum, or Google "Subaru won't start" and you find abunch of owners with the same problem. They, too, have been put off by Subaruservice departments, who obfuscate or shift the blame, and who have nosolution. From the forums one is amazed at the myriad repairs, tricks andwork-arounds that Subaru owners have come up with to try and solve thisnon-starting problem. There is no quick fix. In fact, as of now, 11/28/16,there is NO certain fix, and Subaru Service appears to be as baffled as angryowners. When I picked my 2011 Outback after the fourth incident, the service manager said they still couldn’t find anything wrong on the diagnostic computer, and my carstarted up every time they tried it. One of the service techs told me to use mysmart phone to video the non-starting failure every time it happens, and I amnow doing that. It doesn’t help start the car, but it does allow Subaru Serviceto see what procedures I use to start the car, and it becomes a record ofincidents. Monday, Nov 28, I drove to Auto Zone to turn in my previous battery and to pick up a can of starter fluid. I turned my Outback off in their parking lot. When Icame out of the store ten minutes later, the car would not start. I opened thehood and shot some starting fluid into the air intake, and was then able tostart the car. I drove it one mile and it just stopped dead on a busy streetclose to a RR overpass. I put out emergency markers and donned a yellow vestand waved traffic to drive around me. I popped open the hood and gave theengine another shot of starting fluid, and she started, reluctantly. I drovethe mile and a half home and parked in a position that would make it easy for aflatbed truck to load it up. I called the manager of the local Subaru service.He would not take my call, and did not call me back. My wife and I have cancelled our vacation plans, and have totally lost confidence in this vehicle. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 29, 2016 Share Posted November 29, 2016 if the car is dieing in traffic - definitely report that to NHTSA. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 29, 2016 Share Posted November 29, 2016 Sorry to hear that - well done with the starting fluid, brilliant. That should point to a fueling issue - very rare in Subaru's. 1. check fuel pressure 2. it would be nice to install a temporary fuel pressure gauge permanently in the vehicle so you can see what it's doing when the symptoms present....again, with the idea that they're not going to be able to diagnose it if it doesn't present after towing it or driving it in. I would pull the fuel line the next time it happens, crank the key and see how much comes out. I do that all the time, easy to diagnose fuel supply. Takes like 3 minutes and nearly zero tools/effort to diagnose fuel supply. But I realize most people can't do that. Yours requires a special tool to do so. Quote Link to comment Share on other sites More sharing options...
Silent Bob Posted November 30, 2016 Share Posted November 30, 2016 Check fuel pressure. Also make sure It holds pressure for 5 min or so after you shut it off. Also make sure security light is not staying on when you try to start it- that would indicate an immobilizer issue, and consequently no fuel. (although that "should" set a DTC). 1 Quote Link to comment Share on other sites More sharing options...
Takeitoutback Posted March 8, 2017 Share Posted March 8, 2017 My wife and I purchased our first Subaru - a 2013 Outback (~56,000 miles) in September 2016. In December, it began to exhibit an intermittent starting issue - the engine cranks (slowly) and fails to start approximately 10% of the time. The issue does not appear to be correlated to temperature. We first took the car to two mechanics who were unable to find any problem. Finally, a Subaru dealer told us that a diagnostic test revealed the car required a long crank update and that that should fix the problem. We paid for the update, but the problem persisted. A few weeks later, we took it back to the same Subaru dealer who told us that another diagnostic test found that the body control module was problematic. We paid for a replacement body control module, but the problem still persists. At this point, we've paid $700 for two misdiagnoses. We are fed up and are wondering if any one may be familiar with this problem and how to fix it. Thanks in advance for your advice. Quote Link to comment Share on other sites More sharing options...
