steve56 Posted December 1, 2016 Share Posted December 1, 2016 Need to clean up a set of sohc heads. Looking for advise on best tool for job. Ease of use is my criteria. Dont want to struggle. Company 23 has a nice compressor, but it only works on dohc heads. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 1, 2016 Share Posted December 1, 2016 Mine are average generic tools and they absolutley suck, i can sort of get it to work on some depending on proximity of adjacent structures and how many iterations i want to try with angles, spacing, degrees, but not all and not without ensuing WWF. I'm pretty sure I started a thread years ago about what versions people use, find that thread. I have a socket bolted to one end of some allthread and a cam sprocket on the other end. Maybe I had to cut a notch out of the socket to extract the retainers i think? I just wedge the cam sprocket under my underarm and put the socket on the spring cap thing and just go to town by hand/body weight/brute force method. makes me feel like a man doing an entire head by hand. 1 Quote Link to comment Share on other sites More sharing options...
steve56 Posted December 1, 2016 Author Share Posted December 1, 2016 Mine are average generic tools and they absolutley suck, i can sort of get it to work on some depending on proximity of adjacent structures and how many iterations i want to try with angles, spacing, degrees, but not all and not without ensuing WWF. I'm pretty sure I started a thread years ago about what versions people use, find that thread. I have a socket bolted to one end of some allthread and a cam sprocket on the other end. Maybe I had to cut a notch out of the socket to extract the retainers i think? I just wedge the cam sprocket under my underarm and put the socket on the spring cap thing and just go to town by hand/body weight/brute force method. makes me feel like a man doing an entire head by hand. Yes. Just found that thread. I do Subarus for fun. Don't mind spending money for one thats easy to use. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 2, 2016 Share Posted December 2, 2016 Great glad you found it. Don't mind spending money for one thats easy to use.Smart. You just saved hours and annoyance! Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 2, 2016 Share Posted December 2, 2016 For most modern heads you want one with the removable collets on the spring end that can reach down into the head. There are some inexpensive kits on eBay that have several different sized collets for doing many different sized valves. The screw types take a little more time to use, but they're probably the easiest to set up and use. There are some air powered ones that work really well and are super quick, but are expensive. Quote Link to comment Share on other sites More sharing options...
