tanner93loyale Posted December 6, 2016 Share Posted December 6, 2016 Took my car back to my mechanic and he said that he thought the lack of power could have been an o2 sensor or a clogged cat but i changed both and its still doing it. Ive noticed its fine for the first few pulls in the morning when i first drive it , but as it warms up then it turns gutless... any ideas? I feel like ive tried everything and now its just starting to make me angry. Thanks an advance. -Tanner 93 loyale 4wd 5 speed Quote Link to comment Share on other sites More sharing options...
Dee2 Posted December 6, 2016 Share Posted December 6, 2016 I feel like ive tried everything Hmmm... not much left if everything has been tried. running poorly is possible from many things. how about: Poor air flow poor spark poor compression pcv clogged Any CEL codes ? Timing off Quote Link to comment Share on other sites More sharing options...
tanner93loyale Posted December 6, 2016 Author Share Posted December 6, 2016 Hmmm... not much left if everything has been tried. running poorly is possible from many things. how about: Poor air flow poor spark poor compression pcv clogged Any CEL codes ? Timing off Quote Link to comment Share on other sites More sharing options...
tanner93loyale Posted December 6, 2016 Author Share Posted December 6, 2016 Not running poorly, runs great. Just has no power under throttle after it warms up. Quote Link to comment Share on other sites More sharing options...
DaveT Posted December 6, 2016 Share Posted December 6, 2016 Lots of things might do that. CTS? Did you replace / check both catalytic s? Although, I can't day I've seen one change over temperature - if it's blocked, it should be blocked. But almost anything electric, / electronic can developed failure modes sensitive to heat / temperature. This means anything in the ignition circuits, engine control system, etc is suspect. T in a fuel pressure gauge, so it can be viewed while the malfunction happens. Quote Link to comment Share on other sites More sharing options...
